I have a Saturn L-Series, it has roughly 34,000 on it. I am having troubles with the battery discharging overnight. The dealer has looked at it and has it currently and is puzzled why it will start after it is jumped. Once it is jumped it will run for about 36 hours and then start the cycle again. Does anybody have any Ideas? Marv |
I'd have the charging system checked again. Also have them check for a system drain. Make sure both battery cables are tight. Good luck to you.
| All times are GMT -5. The time now is 08:58 AM. |
