92 saturn was running good. abuot 20 miles in to my drive started to run rought then quit runing.when it starts up in wont run less you theter the gas.idels up and down.wont run smouth.any ideas.
any boby need 92 saturn parts good 5speedtran.body partsgood4good doorspowerwindows.
Clean EGR valve and the ports it connects to.
Have you checked the engine coolant temperature sensor (ECTS), that's prone to cracking? The symptoms of a failed coolant sensor would either be running rich and idling high or fails to run and stalls unless blipping the gas pedal. The original coolant sensor is made of resin and very problematic unless replaced witha newbrass sensor.
thank for info on 92 saturn.billyjoe. |
Why did you post about a SL in the L300 forum?
| All times are GMT -5. The time now is 09:53 AM. |
