Ignition Lock cylinder Won't Come out
Old 06-21-2018, 10:04 AM
MikeGlosta's Avatar
Default Ignition Lock cylinder Won't Come out
2003 LW300
Trying to replace ignition lock cylinder:
Key on Run, tab pushed in but cylinder doesn't release
When I try to pull out cylinder it feels like a tumbler or other part is blocking its removal.
Any ideas on how I can try to maneuver the cylinder out?
Thanks
Old 06-21-2018, 05:31 PM
Is there any way you can push the tab in any further, Mike? IDK, just asking. Seems if you have it pushed in all the way, it should release.
Old 06-21-2018, 05:51 PM
MikeGlosta's Avatar
I've pushed the tab in as far as it can go, the cylinder sprung and came out about 1/8" - then became blocked from coming out further. I'll keep working at it ....
Unless someone makes a reasonable offer and take the car off my hands.
Thanks for the reply
Old 06-21-2018, 10:25 PM
The fsm says to rotate the lock cylinder to start. While rotating cylinder back to the run position depress the locking button. The cylinder should slide out then.
Old 06-22-2018, 04:18 AM
MikeGlosta's Avatar
Thanks, I'll give that a try this morning. Wasn't aware I had to key to 'start-rotate-push tab-run'
Old 06-22-2018, 06:12 AM
Andy IS the L Series guru, Mike. I'm sure that'll probably work for you. Proper procedures are usually the best.
geeve420
08-22-2021 10:50 PM
jspen
10-08-2017 11:30 AM
Nopaynenogayne
12-21-2013 10:36 PM
mpace001
10-24-2012 09:57 AM
richie6
01-13-2009 02:15 PM
Quick Reply: Ignition Lock cylinder Won't Come out
