cooling fan won’’t stop?
Old 09-05-2008, 04:02 PM
saturnl300's Avatar
I have a 02 L300. the cooling fan stays on. the only way it stops is when I pull the 30 amp fuse out of cooling fan number 1. I try to put it back in the next day & the fan starts again. Help
Christian
Old 09-06-2008, 12:31 AM
saturnl300 -
From what you describe, I would suspect that the radiator temperature sensor has failed. It allows the fan to operate after the vehicle has been turned off, to cool down the engine / radiator that has been run hard, or on a very hot day. To verify the problem, disconnect the sensor to make sure the fan stops.
DO NOT DRIVE VEHICLE WITH THE SENSOR DISCONNECTED BECAUSE YOU COULD OVERHEAT
hollywood32401
12-14-2008 08:50 PM
robot
06-25-2008 07:21 AM
mfunk49
01-27-2007 10:13 AM
vetteguy
08-20-2006 09:41 AM
one day
01-20-2006 02:58 AM
Quick Reply: cooling fan won’’t stop?
