I have a 02 L300. the cooling fan stays on. the only way it stops is when I pull the 30 amp fuse out of cooling fan number 1. I try to put it back in the next day & the fan starts again. Help Christian |
saturnl300 - From what you describe, I would suspect that the radiator temperature sensor has failed. It allows the fan to operate after the vehicle has been turned off, to cool down the engine / radiator that has been run hard, or on a very hot day. To verify the problem, disconnect the sensor to make sure the fan stops. DO NOT DRIVE VEHICLE WITH THE SENSOR DISCONNECTED BECAUSE YOU COULD OVERHEAT |
