Water on passanger side floor board.
I just recently got a 2001 L200. We discovered we get water on the right floor board when it rains. The seals are good on the door. It looks like it runs down the door seal to were the hinges are and gets in. Is there a drain somewhere over there that is plugged?
Do you have a sunroof?
No sunroof
Originally Posted by 02 LW300
(Post 62168)
There are drains on the bottoms of the rocker panels. My car got wet from water in the right side A pillar filling up and leaking inside. I found it by removing the plastic trim and hosing the car. The drains were partially plugged and cleaning them did not solve the problem. Down low on the pillar there was a factory sticker covering a factory hole used in manufacturing. Only it had slid down uncovering the hole, I made a new “ sticker “ with gorilla tape and solved the problem.
Andy |
C
(Post 62174)
Andy Could you please take a pic for I could get a idea where to look |
It is behind the plastic trim piece that has the fuse panel access door. I am not going to take my car apart for a picture, sorry. Your car get wet sitting in the rain not driving in the rain, is that correct? If your car gets wet driving in the rain it may be sealant failure in the wheel well area. When my car leaked it got wet in front first then the water ran to the rear carpet. There is no drain for the carpet area.
When its parked
(Post 62177)
I have a parts car partway disassembled, I will take some pictures on Sunday
(Post 62181)
plugs
Of course there are plugs, both in the rockers and in the floor but of course it only matters if you are going to pull out the carpets for drying etc, (as maybe you should do) or just get rid of the water. In that case I recommend a cup. Or a wet vacuum. In the climate where I live in, mold would never be a problem, especially in the summer. Very dry. But if your rig is supposed to be date-worthy, even by rednecky standards, it might need the full carpet treatment. (They will refuse to get in it.)
As to the seals what else can you do but replace them? See if you can get some good seals out at a junkyard or else buy new ones. |
| All times are GMT -5. The time now is 09:59 AM. |
