[img]smileys/smiley7.gif[/img] Okay, I have replaced the fuel filter, the fuel pump, O2 sensor, MAP sensor,Throttle body sensor, coolant sensor, new wires, new plugs,new PCV,battery and alternator tested fine. I have a 1998 Saturn SL and I am having a little problem starting the car, it does eventually, and a bit of a problem with hesitation,The Check engine light is on and the code again was lean fuel. I don't know what to do next to help these problems any suggestions would be great.
i used to have some starting problems with my car as well and it was mostly when it was cold and it was intermittant. (alot of times when the car sat for the day.) there was two things i did to try and improve it and i have yet to have problems with starting. And that was these two things:
- starting only using 89 octane instead of 87 - put in 'isoheet' in order to try and remove any water and condensation that might have built up in the fuel lines. you can get this stuff anywhere. http://www.hardwarestore.com/media/p...#111;nt200.jpg |
| All times are GMT -5. The time now is 05:00 AM. |
