I am having a bit of trouble with my L100 at speeds of over 65mph. Does anyone else have this problem, and if so what have you done to correct it?
check the alignment. probably one too many curb collisions. also check the tires to see if they are wearing evenly, and that they don't have any bulges in them. could be many things, so you can also try taking off the front tires and looking at the tie rod ends, a-arms, etc.to give us a better chance at helping you out. -S-Turn- |
Thanks S-turn. I will put her on a rack and take a look. I'll let you know what I come up with.
S-turn, I had new tires and rims installed. The steering wheel shake is barely noticable. I also had the tie-rods checked and they look good. The sway bars were a bit loose so that may be causing the the minor shake. I'll let you know if this does the trick. Thank you for all of your help. |
I have a buddy that had this problem in his truck... So to fix it, he planned on just tightening the bolts the hold the steering wheel to the column... He ended up with an airbag in the face... LOL
have the wheels spin balanced--- all the shake will disappear |
Balance balance balance all four tires and wheels. If the tires are bad if the wheels are bad replace them.
It''s the tire balance.
| All times are GMT -5. The time now is 03:39 AM. |
