Security Light and Gauge Problem
Old Jul 6, 2008 | 06:26 PM
bills's Avatar
Hello,
My mom has a 2001 L-Series with automatic transmission that is causing her troubles. I looked at it yesterday, and hoping someone here has a suggestion ...
Car started fine, drove it around with no problems. Put it in parkwith the engine running to charge the battery, and sawboth the fuel and temp gauges drop to the "off" (far counter-clockwise) position. The odometer backlight still worked. A second later, the "SECURITY" light came on, and the automatic transmission thumb lock would not depress.
After a few seconds, the gauges came back up, the SECURITY light went off, and the transmission thumblock would depress and allow me to shift into gear.
This happened a few more times.
Any comments or suggestions? Trying to save her a trip to the dealership service department if I can.
Thanks from a newbie.
BillEdited by: bills
Old Jul 6, 2008 | 09:53 PM
Check the CARGING system BATTERY battery CABLES low electrical voltage cause all sorts of electrical problems
Old Jul 7, 2008 | 06:14 PM
Bills
I agree with sw2cam fully, there''s a loose or bad cable in your primary system. Especially check that all the ground cables are tight and in good shape, these often get overlooked and can drive you right up a wall searching for "ghosts" in the machine ...
Old Jul 8, 2008 | 10:55 AM
bills's Avatar
Thank you for the suggestions. Will give them a try ...
Bill
Old Feb 15, 2009 | 03:01 PM
timdurgasr's Avatar
Had the same problem. Found out to be a bad (BCM) body control module. $$$. This has to be done from a diagnostic check.
Susan23
Jun 24, 2015 08:41 AM
jeffandsonia
May 19, 2011 08:19 AM
JayBab
Apr 8, 2009 07:05 AM
Jonest
Apr 19, 2008 06:07 PM
lukeswoota
Nov 3, 2006 08:17 PM
