-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   Rear Shocks & Front Sway-Bar Links (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/rear-shocks-frnt-sway-bar-links-2614/)
garypeterson Nov 12, 2008 01:29 AM
How technical of a job is replacing front sway bar links and rear shock
absorbers in a 2000 LW2? Can a reasonably adept person do the job with a
good floor jack in a residential garage?
And will the car need re-alignment after the new sway bar links are
installed?
Thanks!
TCPAUL Dec 16, 2008 09:58 AM
Replacement is not real difficult.
I suggest using ramps, the more room the better.
I don''t believe that you will need an alignment since all they are are rubber bushings/inserts.
