P0171/p0174
Old Nov 14, 2024 | 08:27 PM
Saturnboy99's Avatar
Default P0171/p0174
2001 Saturn L300 just bought it only has 77k miles on it. Has two fault codes P0171 and P0174 service engine soon light is on. Anyone know where I should start looking? I want to go ahead and get it inspected.
Old Nov 15, 2024 | 08:02 AM
Those are air/fuel mixture codes. Either you're not getting enough air or too much fuel to the engine. Check your air filter and hose for restrictions first. Maybe get a bottle of Techron Fuel System Cleaner and a run a tank of gas with it in there. You might have a sticky or dirty injector.
Old Nov 15, 2024 | 08:36 AM
got it. I put some Lucas in it as well as some guaranteed to pass. Tank of premium. Gonna let that burn through it. I cleaned the mass airflow sensor and the code still came back. Haven’t put many miles on it yet so hopefully after I replace the MAF and let some fuel go through it, itll correct itself.
Old Nov 15, 2024 | 03:11 PM
Replace the fuel filter, and inspect for vacuum leaks after the MAF sensor. Check the six intake boot clamps. With both lean codes it could be a MAF sensor itself. I have factory diagnostic manuals to help diagnosis.
Andy
Old Nov 16, 2024 | 11:08 AM
grcauto8453's Avatar
Premium gas will do nothing for this. You need to look at load values on the scan tool.
Old Dec 20, 2024 | 11:56 PM
TRW's Avatar
TRW
Did you resolve the P0171 & P0174 Codes by replacing the MAF Sensor? If so, did you use an aftermarket OE standards part or AC Delco?
SweetT
Saturn L300
Dec 29, 2016 08:00 PM
imabooger
Aug 5, 2008 08:42 PM
mpl1954
Saturn L300
Jul 6, 2008 09:06 PM
tickwon
Nov 5, 2006 11:00 AM
vinny
Apr 13, 2006 03:33 AM
