Need front suspension torque specs 2001 L200
Old May 12, 2020 | 01:49 PM
Tsport's Avatar
Default Need front suspension torque specs 2001 L200
Hi all. Been a long time since I was on the forum. Had to re-register.
Replacing the front struts on our 2001 L200. I can't find the torque specs anywhere. Library is closed due to Covid-19 so I can't reference the manuals there.
Anybody out there have access to correct manual for this vehicle and can provide me with the correct torque specs for the following?
-Upper strut mount nut (under rubber cap in attached picture)
-Lower strut to knuckle bolts
-Sway bar link to strut
I'm installing Monroe Quick Struts so strut disassembly not needed.
Thanks much in advance!
- Tsport
Upper strut nut under black cap
Old May 12, 2020 | 07:10 PM
lrbraner's Avatar
Top nut is 65 ft lb.
Lower strut bolts are 140 ft lbs.
Not sure about the links, probably around 35 ft. lbs.
Dont believe it is critical,
Old May 13, 2020 | 06:23 AM
Tsport's Avatar
Irbaner, thanks for the info. I'm a bit confused now. Would you mind telling me what manual you got the specs from?
Last night before I saw your reply someone else sent me a copy of specs from AllData Repair specific to 2001 Saturn L200.
It shows top nut 40 ft lbs, strut to knuckle initial torque of 37 ft lbs and then final torque of 66 ft lbs + additional 45 to 60 degrees.
Stabilizer links = 48 ft lbs.
Thinking I might need to check a 3rd source to be sure now.
Thanks again for the input, much appreciated!
-Tsport
Old May 13, 2020 | 07:28 AM
lrbraner's Avatar
Disregard my info, I was getting it from strut installation instructions.
However, I was looking at the wrong instruction sheet.
Sorry for the bad info.
Old May 13, 2020 | 08:55 AM
lrbraner's Avatar
OK, here is the correct specs according to my FSM;
Top nut--40 ft-lbs
Strut to knuckle bolts--73 ft-lbs + 30 to 45 degrees
Stabilizer link nut--48 ft-lb
spasm3
May 22, 2015 03:27 AM
gpeterson
Jan 6, 2015 12:10 PM
kennycoulter
Jul 13, 2012 07:02 AM
furby
Mar 5, 2007 02:46 PM
mjdjlh2000
Jun 15, 2005 02:57 PM
