Miss fire now NO fire
was getting P0300 code, was skipping very bad, no power; So (1)replaced coil pack and ignition module . it started up but was still running rough (2)replaced plugs an boots would not fire after that. Put all the old parts back on still no fire. now the ignition module is not firing (checked the outer pins with test light no power
have power to center pin ) ???? 2002 L100 2.2 |
check the cam and crankshaft sensors
