Lw200 turn signals and caution lights
Hey everyone, just trying to get a little help with my wagon. My turn signal lights and caution light quit working at the same time! Also the clicking of the turn signal was faster before they both quit working. What could the problem most likely be? Bulbs? Fuses? Any advice appreciated
I would start at the hazard switch, cycle it a few times and see if the lights will light. Then you can do an easy bulb check. I have a factory service manual set for the L series cars so I will be able to help troubleshoot.
Andy |
Do what Andy suggested. And check for a broken ground wire. Do you live in an area with squirrels and chipmunks? Some varmits like chewing the wires on cars.
Checked the fuses and it’s not that, and nope no little critters out here. Will check the wires and bulbs next, thanks guys
Checked the fuses, bulbs and wires but can’t find the problem. I think it may be the caution switch itself unfortunately.
Maybe a faulty relay? I don't know, just speculating. If the contacts inside a relay "weld together" it will stop functioning. Do some research and see if your L Series car has a turn signal relay. Andy may know. He's the L Series guru!
I think it is all in the hazard switch.
| All times are GMT -5. The time now is 08:43 AM. |
