L300 ignition
Old May 22, 2024 | 01:33 PM
Kenneth Larew's Avatar
Default L300 ignition
My son lost the last key to his L300....right after we put a timing belt, new tires, fuel pump...and a good bit of other stuff on it. Runs great! Now I can either trash it....or find a relatively inexpensive way to change out the keys and lock barrel without any of the original keys. GM no longer cuts them. Suggestions please?
Thank you
Old May 22, 2024 | 02:05 PM
grcauto8453's Avatar
Call a locksmith.
Old May 22, 2024 | 08:32 PM
You should be able to get the key code at the dealer with proof of ownership. I have done this in the past. Then a locksmith can cut you new keys by code. The key does not have a chip, the lock just looks for the proper key cut.
Old May 23, 2024 | 01:44 PM
I called a lock smith already. According to him he could not cut a key for that car. He said at some point someone might have already replaced the barrel. But whatever the issue...he punched the number in and could not get a key to cut. That's why I'm looking into other options. Sorry, I should have stayed that in the OP
Old May 23, 2024 | 09:31 PM
See if your locksmith will set this up for the correct key code and install it in your car.
jdsloan
Jul 28, 2021 08:47 PM
ckoladawn
Nov 6, 2015 05:16 PM
towerman
Saturn L300
24
May 18, 2015 10:32 PM
profparadox
Nov 18, 2013 12:06 PM
marydawes
Jun 28, 2012 08:24 PM
