<DIV id=post_message_791651>Hey ive got a '94 Saturn SL1 with a manual. The car runs nice but then without warning it will sputter like its losing gas and die. The problem is sparatic. The fuel pump is brand new, the FP relay is good, and i know it's getting fuel cuz ive check the injector. Plugs and wires are new, and so is the battery and alternator. Im out of ideas http://www.saturnfans.com/forums/ima...ies/pissed.gif so i thought i'd join this forum as someone here might have some insight.
By the way im throwing codes #26 - QDM fault #34 - MAF/MAP sensor too low #76 - Soft Flag - MAP does not follow throttle position sensor #27 - Soft Flag - Quick QDM fault Anyone know what these mean? What i should fix?</DIV> |
check air temp sensor, collant temp sensor or egr sensor
