Heater Core question- bypass leak?
Old 01-23-2008, 08:49 PM
mikel200's Avatar
</>I have a 2001 L200. The heater core is leaking;passenger side floorboard is wet with antifreeze.
I know I need to look at theheater core (or O rings), but until I can get to it, will it help to turn the dash temp control to fully cold? I'm wondering if that bypasses antifreeze around the heater core.
All help appreciated.
Thanks,
Mike
Edited by: mikel200
Old 01-23-2008, 09:32 PM
Low Saturn's Avatar
You will need to bypass the core manually. Look on the back of the engine and youll see two hoses going from the engine and connect at the firewall. Disconnect the two hoses from the engine and using a new piece of hose, connect the inlet from the engine to the outlet.
This will bypass your heater core until you can replace it. Luckily replacement looks to be fairly simple. If you need instructions, let me know.
Old 01-24-2008, 10:54 PM
mikel200's Avatar
Thank you! I appreciate the fast reply.
Mike
Edited by: sw2cam
sldood
04-02-2014 07:37 AM
ForgottenOne
10-28-2010 08:14 AM
edfromct
06-30-2010 08:27 AM
heather11787
09-17-2008 06:03 PM
Hooter
05-10-2008 04:09 AM
Quick Reply: Heater Core question- bypass leak?
