Gear shift selector rod 02 l200 can't find one anywhere
Old Mar 28, 2016 | 09:38 PM
Rattatatpat's Avatar
Default Gear shift selector rod 02 l200 can't find one anywhere
I'm looking for a gear shift selector rod for an 02 Saturn l200 impossible to find part # 90523194 just wondering if anyone else has this problem and if you know where to find one besides a junk yard
Old Mar 29, 2016 | 07:51 AM
Do you have a picture of what you need?
Old Mar 29, 2016 | 10:28 AM
I'm not sure how to get a picture on here but all it is, is a small steel rod about 6-8 inches long with a plastic clip on each end to snap on to a ball stud. It's a manual transmission and my problem is I only have third and forth gear. Another name for the part is a gear selector...ill try and upload a pic later
Old Mar 29, 2016 | 11:31 AM
moved to L series section
Old Mar 29, 2016 | 05:00 PM
If it helps at all, I found a listing (out of stock, of course) but the GM name for it seems to be
90523194, Rod, gearshift control to ball stud, left hand drive
Old Mar 29, 2016 | 06:30 PM
Thanks for the help but I've been to 3 auto parts stores and a GM dealer and they said it's been discontinued 😢😤 looks like I'll be roaming through some scrap yards looking for a needle in a hay stack
Old Mar 29, 2016 | 10:48 PM
This part was apparently also used in an Opel.
Gear Link | M&M Dronten car parts
Old Mar 29, 2016 | 10:56 PM
Here's the same co from the Netherlands site
Versnellingskoppeling | MM-Opelparts auto-onderdelen
Old Mar 29, 2016 | 10:59 PM
After hours of research I ended up buying this hopefully I can make it work
http://m.ebay.com/itm/2004-2008-AVEO-MANUAL-TRANSMISSION-SHIFT-SHAFT-ROD-EQUALIZER-NEW-GM-94580711-/261660908428
Old Mar 29, 2016 | 11:00 PM
Here's a German backup site
90523194 | ASP-Shop.eu
