-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   fuel gauge problem (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/fuel-gauge-problem-6239/)
whitelee28 Jan 16, 2012 08:59 PM
OK so i took the car in and had the fuel level sender and pump replaced. The car still goes to full tank of gas and the security light stays on solid and the bell goes off. Also when the key is in the ON position the car doesn't ding it only does it when the car is running. I'm at a loss.
whitelee28 Mar 2, 2012 10:13 AM
Hello all sorry for the late response. I have taken the car to a friend of a friends shop and I explaned the symptoms. The tech tested the gague cluster and it all tested good. The tech said that he is 99.9 percent sure its the BCM. So once the tech can determin if he can program the BCM i will get that changed. Ill keep you guys posted.
whitelee28 Oct 2, 2012 05:32 PM
Hello all I finally broke down and took the car to a Chevy dealer. It is a body control module issue. It's about 749 to replace it and program it and all that. Thanks again for all of your help.
OceanArcher Oct 3, 2012 10:20 AM
Thanks for the follow-up on your problem. Too bad you can't locate a used BCM at a local u-pull-it facility
whitelee28 Oct 3, 2012 11:06 PM
Yeah I had thought about going to a junk yard or eBay. Correct me if I am wrong but some sort of bypass has to be done for the security system to make the bcm work without programming it? I decided to go the dealer route because this is my fiances daily driver. If it was my daily driver I would have done that. I want to make sure she has a very dependable car so I forked out the money. To me it's worth it.
derf Oct 4, 2012 02:04 AM
ummm
can we stick to updating just one of the two threads that seem to have converged to the same topic
thanks
Peace
Derf
