Diagnosing rich condition (P0172/P0175)
Old Jan 24, 2015 | 05:28 PM
goatsuace's Avatar
Default Diagnosing rich condition (P0172/P0175)
I've gone through all the obvious stuff and am still getting these codes.
I warmed up the car, then cleared the codes, then drove it for 10 miles. Never once did my short term fuel trims go below -8, but still after 10 miles it threw the rich codes again.
When the car is cold, the short term trims are really negative (-30). Once it warms up the trims are negative, but just a few points. Temp never gets hotter than 185, but it is wintertime.
Plugs aren't awful, but do seem to indicate it actually is rich (as opposed to only *thinking* it's rich). Fuel rail pressure is 45psi consistent. Vacuum is -18 at idle, -22 at 2500rpms. No vacuum leaks I can find.
I've gotta get this MIL off so I can pass emissions. Here are the results of my scan tool when at idle warmed up.
STFT1 +0.8
STFT2 -2.3
LTFT1 -4.7
LTFT2 -2.3
MAP 4.08
RPM 672
TIMING 9.0
AIRTEMP: 72
TMP 176
MAF: 0.66
TPS 0.8
O2-1voltage: 0.46
O2-2voltage: 0.44
Do not know how to diagnose and/or exonerate the evap solenoid, clogged exhaust, or some of the other possible causes, so all advice is desperately welcome.
Thanks!
Old Jan 25, 2015 | 09:14 PM
What year/Model?
Mileage?
Try cleaning MAF sensor with MAF cleaner with cold engine.
Ever replaced 02 sensors? What's the voltage swing on the front ones?
_________________________
Also, please list the "obvious things" you've already checked so no one wastes time suggesting things you've already done.
Thanks.
Old Jan 29, 2015 | 10:04 PM
Read about the ETCS posted in this forum.
dwain1968
May 6, 2019 10:44 PM
chefbeast5
Jun 16, 2011 09:43 AM
john doe
Apr 12, 2011 03:09 PM
john33
Sep 25, 2010 06:27 PM
tx77015_ls1
Feb 10, 2010 06:32 AM
