Daughters 2005 L series. Need advice.
Long story short. Daughter let friend drive while she was visiting Home (Nebraska)Car in Oregon. Friend kept driving after belt broke. Overheated .Took to garage. Said back head needed repair .Replaced belt,plugs, 156,000 miles
I flew in to pick up car Drove to Seattle to get my daughter at my sisters house On the drive(4 hours)I stopped after ,about 2 hrs. car would not start I let it cool down about 30 mins.Started hard. No code lights. Before I got to Seattle low fluid light came on. Added fluid next day,light went off. Started hard .Drove a couple of towns over .Parked came back hours latter, light came on. Code 0300 Brother in law cleared code. I tried to do drive cycle to get code to come back on .It wouldn't come back .Still starting hard. Had to be back in Nebraska. Drove all day through mountains etc. Plenty of power but at gas stops began to stall. And start really hard. Engine light finally came on code this time 0340 Spent the night in hotel after driving all day .Now Sunday Am . Put in 1/2 jug of coolant.Took 1 1/2 hours to get started. Began to stall at idle speed .re-start real hard .Now even coasting would stall, I could keep it running by dropping into low gear ,or revving in neutral. No coolant in oil Ran good at high speed 75 2100+ miles went through 2 jugs of coolant + 4 bottles of drinking water. Looks like oil down 2 quarts 2005 Saturn L300 v6 |
Originally Posted by prosecho
(Post 32962)
(Post 32962)
(Post 32962)
Did you keep driving that way?
(Post 32962)
Brother in law cleared code. I tried to do drive cycle to get code to come back on .It wouldn't come back .Still starting hard. Had to be back in Nebraska. Drove all day through mountains etc. Plenty of power but at gas stops began to stall. And start really hard. Engine light finally came on code this time 0340 Spent the night in hotel after driving all day .Now Sunday Am . Put in 1/2 jug of coolant.Took 1 1/2 hours to get started. Began to stall at idle speed .re-start real hard .Now even coasting would stall, I could keep it running by dropping into low gear ,or revving in neutral. No coolant in oil Ran good at high speed 75 2100+ miles went through 2 jugs of coolant + 4 bottles of drinking water. Looks like oil down 2 quarts 2005 Saturn L300 v6 What was coolant level when you started? If you're losing that much coolant, the car is likely overheating as you drive and therefore doesn't want to run. Yet you do not describe whether you've observed a coolant leak nor if white smoke is coming from the tailpipe. It's either leaking, boiling off, or burning. P0300 and P0340 are misfire codes. I'd not put much faith in them right now since the misfiring may have been a result of the more severe issues described above. |
(Post 32965)
Did the head work get done? I am sure the head work was done, Mechanic seemed honest.
WHAT fluid???? . Coolant Did you keep driving that way? drove from Corvallis Oregon to Seattle Washington to Nebraska from the time I picked the car up at shop that did work on it. What was oil level when you started?Full What was coolant level when you started?Full If you're losing that much coolant, the car is likely overheating as you drive and therefore doesn't want to run. Yet you do not describe whether you've observed a coolant leak nor if white smoke is coming from the tailpipe. It's either leaking, boiling off, or burning. P0300 and P0340 are misfire codes. I'd not put much faith in them right now since the misfiring may have been a result of the more severe issues described above. Oil was changed -Oil level full Coolant full I kept an eye on the temperature it ran steady about half way on gauge no obvious coolant leaks White smoke real obvious when I started it in morning it was about 30 degrees out side.Not while driving. |
I need more information. Please run both a dry and a wet compression test on her car, and post the numbers here in this thread ....
white smoke out tailpipe often means compromised head gasket -- compression test should shed addl light on the situation
You most likely blew a head gasket by driving it that far with the problems you knew existed. If it got too hot, you may have even cracked a head. The only way you're going to find out for sure is to take it apart.
| All times are GMT -5. The time now is 06:58 AM. |
