-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   Car may be running rich? (P0101) (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/car-may-running-rich-p0101-7784/)
Claplume Apr 21, 2013 07:39 PM
So I finally fixed my p0102 (partly) code and then pulled a similar p0101. And I do KNOW my car is running rich. When I accelerate, it will give a quick studder before launching. The smell is a little different too. I checked my ST FT's on bank 1&2 because I have a v6, and it's suppose to read anywhere between -5 and 5 I believe. I'm running between -21.5 and 16.4. What should I check for first? My cat is fine.. I do have a cold air intake but it's all good. No leaks and my MAF Partly working. Only reading .50 on full throttle. All 6 cyls are running. What can I do to fix a rich running car or... What ever I got going here?
Rubehayseed Apr 22, 2013 08:01 AM
Check your coolant temperature sensor. If it's not within parameters, then this can cause the engine to run rich.
sw2cam Apr 22, 2013 04:20 PM
Claplume Apr 22, 2013 10:53 PM
:cool:
Originally Posted by sw2cam (Post 36722)
Is that a good ...... Or bad? Is that lagit?
sw2cam Apr 23, 2013 09:05 AM
ETCS may be the most common reason for running rich on any car.
Claplume Apr 23, 2013 12:14 PM
And that's an Electric Throttle Control System right? Why would that do it? I know cars but not that great..
sw2cam Apr 23, 2013 12:37 PM
Electronic Temperature Control Sensor just like we have been saying.
