-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   A/C is not workin in my 2003 Saturn L200 (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/c-not-workin-my-2003-saturn-l200-3266/)
kaushal402 May 16, 2009 03:22 PM
Hi,
need help, in my Saturn 2003 L200 air conditioner is not working, when i push the AC button the light on the AC button turns on but the cool air never starts. even i can not feel the sound or load on engine when i turn the AC button on.
Please guide.
Thanks.
Kaushal
derf May 16, 2009 05:47 PM
sounds like all refrigerant has leaked out of system. once it gets too low, the compressor will not kick in
kaushal402 May 17, 2009 04:51 PM
Thanks for your quick reply, is this something can be rectified by refilling the gas only??
sw2cam May 17, 2009 07:11 PM
I think you should take your SATURN to someone (SATURN DEALER) that knows the car in question and knows how to work on the A/C. Just one thought, if it "leaked" out do you think it'll not leak out if you refilll it?
OceanArcher May 17, 2009 09:21 PM
Hmmm - 2003 -- seems I have heard of more than one in that era with A/C loss of coolant. Something about a safety valve in the high pressure line not working properly. I think I'd have the experts look at it .....
kaushal402 May 18, 2009 07:49 PM
Thanks a lot for your help
Thanks a lot for your help, i will visit a autoshop shortly.
Tidbits7 Feb 1, 2017 10:46 AM
did you try a leak detector dye that you can get from a auto part store ?
It will let you know if you have a leak and where it is , like mine was in a hose & it cost me $23 for the hose I put it on and works fine . Spent $4 on leak detector and $5 on a UV Flash lite, $23 for hose vs paying one thousand to have it fix. Hope this help
Dtruck1 Feb 3, 2017 03:46 AM
Just be sure to vac the system down real good to get the dye out after you replace the bad parts. The dye will displace the Freon and add inefficiency to the system. Just a heads up. Some people vac down to a certain inch of mercury, but I go with a micron gauge and vac it down to a sustained 100 microns. That means vac it, then isolate the system and see if the gauge increases, that means there is still moisture in the system.
derf Feb 4, 2017 09:44 PM
8 year old necroposting? (sigh)
