Brake lines
I have a rear driver side brake than that has rusted out and it spewing break fluid, I was curious if anyone has the diagram for the break lines? It looks like the line I'm needing to replace goes around the gas tank and I was hopping i wouldn't have to drop the tank.
2005 saturn l300 |
Get a roll of the correct size, probably 3/16, and run it your way.
Here's the manual. https://charm.li/Saturn/2003/L300%20V6-3.0L%20VIN%20R/ |
Might want to consider that the other lines in the system are potentially in about the same condition, given the age of the car
I highly recommend getting the copper-nickel version of brake line.
Costs a little more, but so much easier to work with. |
how would you keep the master cylinder from running dry if the repair needed to be done over several days?
| All times are GMT -5. The time now is 10:16 AM. |
