2003 Saturn L200 BREAKS!
Old Dec 25, 2018 | 09:37 AM
boss's Avatar
Default 2003 Saturn L200 BREAKS!
I have an 03 Saturn L200 that I change the rear brake pads on and the wheel cylinder. Every time I pump the brakes to bleed them the wheel cylinder pops and brake fluid pours out. I have no clue what's causing the problem. Not sure if I have something wrong or if the wheel cylinders are bad from the parts store. Can someone please help me?
Old Dec 25, 2018 | 09:54 AM
You have to bleed the brakes with the drums on.
Old Dec 25, 2018 | 10:27 AM
Astute observation, Dr.
Old Dec 26, 2018 | 11:36 AM
boss's Avatar
yes sir I do bleed them with the drum on. Still bust every time.
Old Dec 26, 2018 | 11:01 PM
You must not have them assembled correctly. Please post a picture of the bottom also. I suspect that the shoes are not installed correctly. Drum brakes can be a real pain to get correct.
Old Dec 27, 2018 | 08:48 AM
They're NOT assembled correctly. Look at the notch in the wheel cylinder, The brake shoe is NOT seated in the groove. You have nothing to block the pressure of the fluid from popping the cylinder out. Put those shoes in the slots, NOT outside them. Drum brakes are not that difficult if you just pay attention to how they come apart. My Dad taught me to do one side at a time, so you can always use the other side as a reference.
Old Dec 28, 2018 | 01:34 PM
boss's Avatar
You are correct! I took them apart and reassembled them and there perfect! Thanks a lot!
Old Dec 29, 2018 | 01:21 AM
Glad to hear!
Old Dec 29, 2018 | 08:16 AM
Happy to help. That's what we're here for.
Old Dec 29, 2018 | 10:08 AM
I haven't worked on drum brakes since my buddy taught me how to in high school. I thought it was nasty then and I have succeeded in avoiding them for 30 years running.
Power to ya for fixing em and power to Rube for detecting an issue from a single pic. See Rube .parts of your memories can't be lost no matter how many times they slice your brain 😄
