2002 l200 coolant question
Hello all. I am going to be doing a coolant and a thermostat change in the near future and had a question about dexcool. Do i need to go to a gm dealer to get the dexcool or can I go to a auto parts store and get it there? I have heard lots of horror stories about putting the wrong type of coolant in. Any advice would be appreciated.
If you still have your owners manual, refer to it. It will tell you what type of antifreeze to use and how much the system holds. If you can find the Dexcool anywhere besides the dealership, it will probably be cheaper. I'd try Walmart first, then your friendly neighborhood auto parts stores. Just call them and ask if they have the dexcool and how much per gallon. Then call the stealership and ask them.
It's all up to you. I personally don't use a flush unless the old antifreeze it just absolutely filthy. I remove the thermostat, put it back together and flush it with the garden hose until it all runs clear. Then I drain the system again and fill it with a 50/50 mixture of the recommended coolant.
