2000 ls1 Doors will not automatically unlock , please help
doors lock when shift into gear but will not unlock automatically.
This is a user programmable feature, so check the owner's manual for the sequence of key position and switch operation needed to re enable the auto unlock function.
If that does not work, sounds like a BCM issue (Body Control Module)-- may need to be reprogrammed or may be defective and require replacement |
Camaro?
ls1 = base model l series early on
Woops. I promise I'm not really that dumb...
you can promise all you want but Google's already indexed this thread so the Cat's no longer in the Hat
I guess the cat's out of the bag then?
I thought we were trying to get into the cat?
