02 L200 dead speedometer
Old 01-06-2009, 02:05 PM
cherokee9's Avatar
recently changed oil and after 2nd or 3rd day, looked at speedometer and it showed 694578 and it does not change. The approximate milage should be about 92350. The trip meter does not work either. Anyone got any suggestions. Tried to reset oil button, did not change. even disconnected battery, but did not help.
Old 01-06-2009, 03:30 PM
On the Instrument Panel Junction Block (IPJB) under the dash, check the IGN 1 fuse
Old 01-08-2009, 02:09 PM
cherokee9's Avatar
Thanks for the info Oceanarcher. Checked the fuse in both the block on the side of wall on passenger side and also the fuse block under hood. all seem OK. I am wondering if a connection to drive train may be unplugged but I don''t know where to look.
Old 01-08-2009, 02:36 PM
Well, the vehicle speed sensor (VSS) is located on the transaxle housing. Make sure the connector is tight ...
Old 01-08-2009, 06:15 PM
cherokee9's Avatar
The speed sensor plug appears clean and is securely plugged in. Still no help.
Old 01-08-2009, 06:22 PM
Sounds like the BCM
Old 01-08-2009, 07:53 PM
(sigh) ... Yeah ...
Did not want to jump to that, but sw2cam has the next logical place to look. Either that, or the speedo head itself.
Old 01-09-2009, 01:01 PM
cherokee9's Avatar
I don''t know what that is or where it is, but it sounds expensive. Can you help with more info.
Thanks
Old 12-06-2017, 09:46 PM
Jack Lance's Avatar
Default Are you still there ?
I have the same problem with the same car make and model 9 years later. Was told that a rebuilt instrument cluster would solve the problem. Now where do I get a rebuilt instrument cluster lol ?
Old 12-06-2017, 09:48 PM
You were told wrong.
The BCM is toast. It stores the mileage and cannot be altered
Quick Reply: 02 L200 dead speedometer
