-   Saturn L Series Sedans & Wagons (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/)
-   -   01 L200 died without warning (https://www.saturnforum.com/forum/saturn-l-series-sedans-wagons-26/01-l200-died-without-warning-1544/)
cali_saturn Dec 11, 2007 11:33 PM
Newbie here so easy on the flaming...
Have an 01 L200 that never had any problems.
Tonight I was driving normally, made a left hand turn and BAM car dies.
Electrical still works, when she cranks its healthy electrically but seems
hollow.
Had a similar problem on my jeep, and it was the throttle positioning
sensor. Found another post here that hinted at that and showed how to
test for good fuel pump, but I was wondering if there may be something
else I'm missing? Any ideas?
Also, is there a way on saturns to check fault codes w/o a scanner? I
know on most of my past cars there was a sequence for turning the keys
or an actual diode you could turn. Is there something like this?
Thanks for the help. I work 24 hr shifts so I can't get back to her till
thursday. All ideas appreciated.
HATCHET_SATURN Dec 12, 2007 05:28 AM
does it seem to sputter at all when you crank it over?? try some starting fluid in the throttle body and see whut she does. if nothing then the TPS could be at fault..(one of many things) i dunno much bout readin codes on an 01 but im pretty sure a code reader is required
cali_saturn Dec 13, 2007 07:41 PM
changed TPS, changed CPS... any other ideas? How do I check spark with
that weird coil pack? Does this sound like a timing chain??
HATCHET_SATURN Dec 14, 2007 02:00 AM
HMM...JUST PULL A PLUG OUT AND HAVE SOMEONE CRANK IT AND SEE IF THERES SPARKY..DID YOU TRY THE STARTING FLUID?
Edited by: sw2cam
sw2cam Dec 18, 2007 09:46 PM
PS: The next post with a tracker incerted will get the IP, e-mail, and user name blocked..............
original007 Jan 4, 2008 06:57 PM
there is a timing chain recall for the 01 2.2l certain vin #s. Is there compressionEdited by: sw2cam
