saturn Ion 2007 2.2 - wheel bore
I have Saturn ion 2007 2.2 and it has WHEEL with CETRE BORE DIAMETER OF 57.1 MM.
I am thinking to buy an used wheel to use as spare If i buy an used 2004 honda civic wheel of 56.1 mm centre bore...will it be a problem ? All reply will be highly appreciated. Thank you. |
It won't fit over the hub.
If honda wheel bore is smaller than saturn wheel bore, the saturn hub is too large to fit though the bore of the Honda wheel. |
(Post 76552)
If honda wheel bore is smaller than saturn wheel bore, the saturn hub is too large to fit though the bore of the Honda wheel. Thank you again !! |
| All times are GMT -5. The time now is 08:31 AM. |
