-   -   rear defrost will not shut-off (https://www.saturnforum.com/forum/saturn-ion-22/rear-defrost-will-not-shut-off-13972/)
morsed4@gmail.com Nov 4, 2025 12:20 PM
After driving in heavy rain, the battery was drained, and the light on the defrost switch was on with the car off. 2004 Ion. Hopefully, someone may have a suggestion.
Thanks
02 LW300 Nov 4, 2025 12:57 PM
Troubleshoot the discharged battery first, the rear defroster will probably correct itself. Heavy rain should not be an issue unless you have been driving through deep water and you have missing under body panels.
morsed4@gmail.com Nov 4, 2025 01:15 PM
Thank you. I will look into this this afternoon.
derf Nov 4, 2025 01:38 PM
Ion battery is in the trunk, no?
There are leads that run the length of the car to the front under hood area, so Andy's suggestion is still valid. My comment comes from the thought of a possible trunk leak
derf Nov 4, 2025 01:47 PM
I think the battery sits in a vented compartment in the trunk. I suppose water could possibly splash up through the vent and cause problems with the battery.
morsed4@gmail.com Nov 4, 2025 02:02 PM
Yes, the battery is in the trunk.
