poor heat
Old 11-20-2015, 01:15 AM
quadcoupe's Avatar
Default poor heat
put a new thermostat in my Ion and since then I have less heat so I just want to be sure I did everything right. From the water pump is the side for the spring and pill for the thermostat right and that plastic thing should hold the placement of the thermostat. The new thermostat is a 180 degree just like the old one but the temp gauge reads just a little lower and with the heat on high it is only passable where before the replacement I had all the heat I needed. Warmup is about the same only a little less total temp and less heat. Going to put a header on this car and replace the thermostat and just don't want to miss anything
Old 11-20-2015, 08:24 AM
Where'd you get it? If at your local Autozone or Advance, odds are that it's defective out of the box. I'd suggest getting one from your local GM dealer. If you get aftermarket, get a Stant. You might also just be low on coolant. Did you remember to top it off after the change? You might also try flushing the heater core.
Old 11-20-2015, 04:17 PM
goaliemo's Avatar
Well, I don't remember anything for the thermo housing being plastic.
Overall engine temp being a tad lower is normal. As to why you don't have as much heat in the car, heater core is probably on its way out.
Header, don't do a shorty. Its no better than stock. Either go mid length or long tube.
Old 12-02-2015, 04:32 PM
quadcoupe's Avatar
headers did not fit,they ran into the thermostat housing with #4 pipe While exhaust was off I replaced the thermostat and now the gauge moves to the middle and I have more heat than I can handle so all is good except I am upset about the headers but I have fixed all exhaust leaks and I cannot remember when this little POC was so quiet
Old 12-03-2015, 12:12 AM
goaliemo's Avatar
I had that issue with my redline. Heat up that spot of the header with a torch, tap it with a hammer until there is a small dent, and youll be fine.
07-14-2015 08:35 AM
joma1993
11-17-2014 10:30 PM
drivewayguy
01-06-2014 11:04 AM
RjION
02-10-2012 05:06 PM
RodDoe
03-18-2010 10:56 PM
Quick Reply: poor heat
