-   -   performance (https://www.saturnforum.com/forum/saturn-ion-22/performance-10123/)
quadcoupe Jul 18, 2015 09:31 AM
performance
does anybody know what the performance of my little Saturn should be?
I have the standard motor with the CVT trans,it seems proper but I have needed to replace the O2 sensor 3 times now and Advance Auto is questioning if I have a bad cat causing the problem. I still get 30 mpg and to me it seems the same as new but I could do a 0-60 and dream I am in my other car
derf Jul 18, 2015 11:19 AM
dude where IS your signature?
Keep it on all posts please.
This is exactly why we have them
Can't answer cause I don't know what your ride is!
And which O2 sensor? Front or rear?
First of all, if you're buying noname electronic parts at Advance, that's likely the problem. If all three are rear O2 sensors, then there is a chance your cat is not functioning as designed but you would get an 0420 Cat Effic below Theshold BASED ON the rear 02 reading. But if you can replace the sensor and not have it trigger an 0420 50 mi later, I'd say it's a ****ty part (rear O2 sensor).
What code are you getting to trigger you to replace the 02 sensor (presumably rear)? Pxxxx, please)
Please do tell.
Rubehayseed Jul 18, 2015 09:48 PM
Never, ever buy electrical parts from Advance or Autozone. Having worked for both years ago, I can testify that their electrical parts aren't worth a damn. You might get a decent one sometimes, but for the most part, just NO. I won't buy any of their stuff. I get mine from a NAPA store when available, or the stealership. Sure, I pay more, but I don't have to keep trying to return crappy parts that cost me time and more money in the long run.
quadcoupe Jul 19, 2015 07:58 PM
does somewhere around 9-10 seconds sound right for a 0-60 time ? There is only 1 O2 sensor on my ride
goaliemo Jul 19, 2015 10:06 PM
Huh? Last I checked ions have 2. All 5 of mine do. Or do you have an aftermarket down pipe? Still though. It should be way at the end of the down pipe.
quadcoupe Jul 23, 2015 11:59 AM
looked better and found a O2 sensor after the cat,anyway does anybody know what 0-60 should be on this slow car
derf Jul 23, 2015 12:10 PM
search google using the search phrase
2004 ion coupe 2.2L 0 to 60
goaliemo Jul 24, 2015 02:26 AM
8 seconds....
derf Jul 24, 2015 08:23 AM
(sigh)
goaliemo Jul 24, 2015 10:43 AM
I know.
