New Member In Need! Ion 3.
Hey guys, I'm new the forum but am in need of some urgent help. I just recently bought a 05 Ion 3 I've already replaced both wheel bearings, and CV axles the issue now is that I basically have no throttle, I started the car after a weekend vacation and could floor the gas pedal with no reaction. Looked into it online and most things point to the APP sensor. I have a engine light on and a power reduction light, havent had a chance to see the codes tho.
You need to check the codes before throwing parts at it. |
Originally Posted by 02 LW300
(Post 59551)
There is also wiring and a pcm involved. So codes are only the beginning of the diagnosis. |
There is a wiring junction under the drivers side kick panel that can become corroded due to water from wet floorboards (snow from winter is a good way to soak them)... pull the panels off, pull the wiring plug apart (after disconnecting the battery) and check for corrosion... even if not corroded, spray both ends with WD-40 and after that dries, slather in some dielectric grease and reconnect... IF your problem DOESNT go away, then check the APP sensor and then the throttle body |
Rather than use WD-40, why not use CRC Electrical Contact Cleaner? Then plug and unplug the harness a few times to help "sweep" the contacts clean.
You could... the only real purpose of the WD-40 is to displace any water that could remain... |
Thanks guys!!
Thanks for letting me know about the other sensors, and sorry for the late reply but i fixed it a few days after the post bought contact cleaner and cleaned my sensors tore up my throttle body and cleaned it to.
Which sensors did you clean and with what? some are easily destroyed so it would be helpful to know what works. Thanks
(Post 59787)
| All times are GMT -5. The time now is 06:55 AM. |
