Need help with Window issues!
Ok...my passenger side front window is refusing to go down. I've taken the entire door apart, the entire window system apart, and I have determined that the motor is working, since it goes up, the switches are working correctly, and that it is a nightmare to try to fix it. Any suggestions? Aside from the obvious: trace the wires to see if any are toasted. Thanks.
Replace the regulator and motor
