-   -   Inner tie rod boot clamps (https://www.saturnforum.com/forum/saturn-ion-22/inner-tie-rod-boot-clamps-13105/)
That1dude May 21, 2024 01:46 PM
I recently replaced the inner and outer tie rod ends on an 07 Saturn Ion-2 2.2. The outer part of the boot that holds onto the rod had a small pinch style ring clip but the inner end of the boot where the bigger diameter is has a one time use clamp that breaks or needs to be cut loose. The new tie rod ends didn't come with new boots or clamps, and I didn't have any zip ties, so I just installed the boots without them. They fit pretty snug, but is this OK, or should I try to find some clamps? It's been said that they're hard to find. Are zip ties or anything really necessary?
Thanks
grcauto8453 May 21, 2024 02:20 PM
Get some heavy duty zips and secure them. They will walk away if you don't.
That1dude May 21, 2024 02:58 PM
Got it, thanks
