-   -   im going to cry (https://www.saturnforum.com/forum/saturn-ion-22/im-going-cry-9182/)
mandee_07 Jan 8, 2014 06:41 PM
im going to cry
I have a check engine light on in my car :(
Onstar ran a diagnostic and says my my emissions system isn't running correctly. Says if the light doesnt go off within 7 trips I need to take it in within 7 days.
Where the hell do I start? I dont have money for this right now ugh!!! I wanna cry.
Rubehayseed Jan 8, 2014 09:56 PM
Did you get some gas today, Mandee? If so, it may be as simple as a loose gas cap. Don't freak out yet. Even if it's not a loose gas cap, it could be the gasket around it not sealing properly. You can get a new gas cap, but I'd recommend trying one from a GM dealership before trying the aftermarket junk that's out there. But, that's ONLY if you need one. Tighten that gas cap until it clicks. Then it may take a few drive cycles for the code to clear itself.
mandee_07 Jan 8, 2014 10:44 PM
Havent gotten gas since sunday. Should I go by advance auto and get the code?
derf Jan 8, 2014 11:06 PM
yes. Post the entire code Pxxx where x are numbers. We'll try to help you sort it out, And screw the 7 day limit --- last I checked onstar techs were not trained in interpreting check engine light.
Get the codes read before doing anything else anf post here. Remember the Pxxx not the description the Autozone lackey gives you.
mandee_07 Jan 9, 2014 07:00 AM
Ok I'll go by there at lunch or after work today.
Rubehayseed Jan 9, 2014 07:47 AM
I agree with derf about the codes. And just for s*^%s and giggles, check your gas cap anyway.
mandee_07 Jan 9, 2014 10:55 AM
I have a gas cap message if its not right...but ill do it anyways just for you
mandee_07 Jan 9, 2014 11:32 AM
P0446
Thats the code
Rubehayseed Jan 9, 2014 01:48 PM
Check the hose going to your EVAP canister and make sure it hasn't come off or maybe gotten crimped somehow, Mandee. It may be that simple.
mandee_07 Jan 9, 2014 01:57 PM
Where is that located? lol I can check it if you give me a location. Pretty handy like that...just havent learned locations of everything.
