How often to change the transmission fluid filter?
Old Nov 12, 2024 | 08:31 PM
That1dude's Avatar
Default How often to change the transmission fluid filter?
2007 Saturn Ion-2 2.2
I did a drain and fill not even a year ago along with the filter and ended up having to drain again due to putting a whole in my transmission casing. After I repaired it, I added what was drained back in. I hadn't done it at the suggested interval from the Haynes manual, so I was planning on another drain and fill after a couple of oil changes. Should the transmission fluid filter be changed again?
Thank
Old Nov 13, 2024 | 02:50 AM
Always take the opportunity to have clean fluid going though clean filters. If you were off maintenance schedule, since you can't do a complete system drain, you probably still have some skanky transmission fluid in there. All the more reason to start with a clean filter to catch more of that stuff. Especially when the cost involved is minimal.
Old Nov 13, 2024 | 08:15 AM
I agree with derf, 100%. There's no point in running fresh fluid through an old filter.
Old Nov 20, 2024 | 06:39 AM
That1dude's Avatar
Both replies make sense. I thought I replied back. Must've forgotten
Thanks
Old Nov 21, 2024 | 10:38 PM
There's always that1dude that forgets.....
Bobbed06
Oct 31, 2012 09:09 AM
turbochargedv8
Nov 15, 2009 07:18 AM
s1dest3pnate
Nov 20, 2008 03:20 PM
DaniSC2
Engine & Internal
Apr 30, 2008 09:08 PM
DaniSC2
Apr 30, 2008 11:41 AM
