Engine swap and drum to disk conversion
Old Jan 26, 2025 | 08:33 AM
Saturn505's Avatar
Default Engine swap and drum to disk conversion
Good morning everyone,
quick question.
Does anyone know how I can convert my drum brakes to disk on my 2005 ion Quad, and what engine swap can I do, what engines from GM can swap with my ion.
thank you
Old Jan 26, 2025 | 10:24 AM
DropDead's Avatar
quick question.
thank you
No direct rear disc swap without converting to 5 lug. Which isn't to big of a project. I did mine in an evening.
What's wrong with the engine?
Old Jan 26, 2025 | 12:40 PM
Saturn505's Avatar
How do we change to a 5 lug?
the engine is just making a loud rattling noise and loses a little power when I drive it, it’s a 5 speed
Old Jan 26, 2025 | 01:13 PM
Saturn505's Avatar
im also thinking it’s the knock sensor
Old Jan 26, 2025 | 10:49 PM
DropDead's Avatar
I used a ion redline front hubs, calipers, pads/rotors and brake lines.
Rear I used a complete redline/cobalt SS rear beam, with hubs, brake components, hoses, and parking brake cables.
​​​​​​​If engine is making rattling noise and down on power you're probably looking at a timing job. Timing tensioners are the known weak point. I'd pull the valve cover and see if the chain is stretched.
Being you're a 5 speed car front swap is plug and play.
Old Jan 28, 2025 | 08:50 PM
Saturn505's Avatar
The conversion sounds a little intimidating lol
so what engine besides a Saturn works, I keep hearing a cobalt might swap
Old Jan 28, 2025 | 10:10 PM
Any 2002-2006 2.2 GM ecotec in any GM car long block will work in your Saturn. I put a 2002 Oldsmobile Alero 2.2 in my granddaughter’s 2000 LS1 Saturn. The first generation 2.2, 2000-2006 fit. You have to remove everything down to the long block and install your manifolds and accessories. It will probably be easier to repair your engine if it runs and has timing chain problems.
Old Jan 28, 2025 | 10:14 PM
The later 2.2 will not work in the earlier cars. My 2007 Cobalt engine will not work in your 2005 Ion.
Infectedbowl28
May 30, 2024 06:37 AM
2005SaturnRelay2
Saturn Relay
Dec 7, 2022 09:19 PM
gcthrasher
Mar 5, 2012 05:18 PM
Riley89
Oct 8, 2010 11:39 PM
deathkricket
Jul 16, 2009 05:18 AM
