engine light flashing
Old Jun 12, 2006 | 05:32 PM
dec29p's Avatar
hi i need some help. i just recently changed my battery and now my engine light blinks when i'm driving. and stays on when i'm idleing. the funny thing is i went to 3 different places to have the codes read and they all came back as errors. some body please help. and my warrenty is up too.
Old Jun 18, 2006 | 01:53 PM
skdr112888's Avatar
yeah, the saturn ion is full of sensors everywere, you do one little thing and it throws your check engine light, the sensors are really sensitive, thats the only thing I dont like about my car.I dont know what your light could be going off for, try disconnecting the battery and reconnecting it thats what I did to reset my check engine light, when I changed my oil, It might work, but Im not sure
Old Jun 18, 2006 | 06:37 PM
keith's Avatar
If you have a flashing check engine light, the your catalytic converter
is in danger of being damaged. Changing a battery should not
cause this, unless someone accidently reversed the battery
cables. This is easily done if the wrong battery was
installed. Many batterie sizes come in two versions, the
difference being the location of the + and - terminals.
If you did not install this battery yourself, look at it and see if it
appears that the cables are "streched" to reach the terminals or are
crossed. This could be what has happened to you. If the
cables were accidently hooked up backwards, you will probably need a
new computer and thats not going to be cheap. The place that
installed the battery wrong should be responsible and have insurance
for this, if you can prove it. The wrong battery would be a good
clue.
buddy5595
Aug 9, 2020 12:13 PM
Moorecd
Aug 7, 2010 11:23 AM
jblckwd
Saturn L300
13
Apr 16, 2009 11:07 AM
coconutprincess
Mar 22, 2007 10:52 PM
donclaypool
Engine & Internal
Jan 31, 2006 10:16 PM
