Brake problem
Old Apr 11, 2024 | 01:03 AM
KevinB's Avatar
Default Brake problem
Ok I have a Saturn ION and the brake pedal goes almost to the floor. I started off by bleeding the brakes and that didn't work so I changed the master cylinder and that didn't work so what's next? There are no leaks that I can see. Do you think it might be the booster? I mean there's not much left
Old Apr 11, 2024 | 07:58 AM
grcauto8453's Avatar
Could have a bad hose. Could have a bleed that didn't work. How did you bleed them? Master bled before install?
Old Apr 11, 2024 | 08:12 AM
Make sure the hose to the brake booster check valve hasn't come loose or split. If it looks okay, maybe replace the check valve.
Buckeye_Guy
Aug 8, 2024 10:51 AM
2008vueXE
Jul 1, 2024 06:34 PM
tvtn
Jul 9, 2021 04:21 PM
vicgac
Jun 12, 2012 07:22 AM
ngrome
Mar 16, 2011 04:16 AM
