In the 2005 (panasonic) saturn ion 2 standard radio w/single cd player head unit where are the head unit output leads located and what do they look like or could you tell me how to install a rca line converter using this particular head unit?
RCA line converters usually run off of the speaker wires (aka output
leads?) If you're installing your amp in the trunk, which is easiest since the battery is right there, just tap into the rear deck speaker wires. |
