04 Saturn Ion trans dipstick broke in tube
Hi i just joined so hello, ive been having issues with what i assume is transmission (going uphill or speeding up causes my rpm to jump or "cough") so i wanted to check my dipstick, i found what i believed to be my dipstick and started pulling on it, well it was ziptied down where the nut is suppose to be and i pulled a bit too hard, causing my dipstick to break off in the transmission tube. i put "dipstick" in the title like that because i read a lot about how apparently saturns dont have trans dipsticks, ill attach an image of what i pulled on
https://cimg5.ibsrv.net/gimg/www.sat...fd87ced95b.png this is what i pulled on, but mine came out with practically the whole stick broken off in the tube Thats an image i found in a youtube video, but mine just broke off essentially. so im aware there is a filter but i just want to make sure that my car will be okay, i dont want to fully flush it as theres a LOT of miles on this car, but if its fine in there im not too worried about it. |
Dipstick or no dipstick is determined by transmission type. Your Saturn appears to have a dipstick, or a two piece dipstick. Do you have an Ion Coupe? If so you may have a “CVT”, as in constantly variable transmission. This particular transmission has proven to be problematic and takes special fluid. It also has a dipstick. I would not worry about leaving the lower part of the dipstick where it is.
| All times are GMT -5. The time now is 08:41 AM. |
