03 Ion checking trans fluid
No dipstick on these so you have to check by pulling the overfill plug. The transmission needs to be at normal operating temperature. The car should be raised and level. when checking and/or adding fluid the engine needs to be running. Run the transmission through all the gear selections slowly. If/when fluid starts coming out of the overflow port you have enough fluid in the transmission. MAKE SURE THE CAR IS RAISED AND LEVEL WHEN DOING THIS.
hey,
Goalie is half umpaloompa and he will not take kindly to your vicious insensitive remark. That is if he ever comes back to the board
I knew the answer--just wanted to see how sarcastic your response was.
You did not disappoint.
Oh sorry here is the proper procedure for the ION with the AF23-5 automatic transmission:
Park the vehicle on a flat level surface.
Confirm that the ATF temperature is at normal operating range of 60–70°C (140–158°F).
NOTE
Important
ATF level increases as it heats up. Therefore, inspect the ATF level at its normal operating temperature, on a flat level surface, to ensure accuracy.
With the engine at a base idle, apply the service brakes and then slowly move the automatic transmission gearshift selector through all ranges, returning to the PARK position.
Remove the fluid level indicator and wipe the fluid level indicator with a clean, lint free cloth. Reinsert the fluid level indicator into the fluid level indicator tube making sure that the fluid level indicator is fully seated into the fluid level indicator tube.
Remove the fluid level indicator and verify that the ATF level is within the "HOT" level markings as indicated on the fluid level indicator.
NOTE
Important
If the AFT level on the fluid level indicator is different from front to back when inspecting, add or remove ATF until the lower of the two readings is within the correct level.
Adjust the ATF level as necessary, by adding or draining ATF, in order to obtain the desired reading in the "HOT" range on the fluid level indicator.
NOTE
Important
NOTE
Important
