No crank, No start, not even a click. 2008 Aura 2.4
Old Sep 7, 2024 | 08:28 PM
kylerzinn's Avatar
Try checking for continuity and resistance between the positive battery terminal and the positive battery lead and where it attaches to the starter. Some go straight through, some are branched.
Measure the resistance between your negative battery terminal and an unpainted frame ground
Since you are getting no clicks at the starter, check that the wire from the ignition relay that enables the starter is being energized.
I tested the voltage/continuity for the can bus, the battery (for load and I recharged it), the battery terminals, all of the fuses, the starter, the ignition switch, the TRS, and the grounds. I think that's all, it is all very easy to test when you have a diagram like this for the ECU connector:
(https://charm.li/Saturn/2008/Aura%20...trol%20Module/) *My car is le5*.
I also DTC scanned to see if the ECU was the only computer not communicating which was conformed already with the initial u0100 code. After all of these tests, we were certain that it was the ECU. Bought a new one for about $100 on eBay that was programmed to vin, did the security key relearn, and the crankshaft position relearn with a friends dtc reader/programmer, and it started right up. However, it seems like I could've done it without the scanner, just by going through the protocol with the rpms, parking brake, a/c off, etc.
I am facing another challenge though that I posted about on the Saturn Aura thread on this website.
gpartrid
Jul 29, 2024 10:17 AM
wayno
Saturn Outlook
11
Sep 10, 2023 08:51 PM
kcilee
Jul 31, 2021 07:19 AM
tamyreaves@yahoo.com
Nov 18, 2018 05:53 PM
HiVuhltage
Dec 20, 2016 07:15 AM
