-   Saturn Aura (https://www.saturnforum.com/forum/saturn-aura-34/)
-   -   Need help! (https://www.saturnforum.com/forum/saturn-aura-34/need-help-5484/)
ballin00gtp Feb 21, 2011 06:53 PM
Need help!
hey everyone.
im new here and i just bought an aura for my wife about a month ago. a 2008 XR. love the car so far, but today she noticed the auto dim mirror with compass wasn't working, the sunroof wont open neither of the heated seats are turning on, and only the drivers side window wont roll down. could that be a fuse in the car? i didn't think it was since there are so many different things at once, and only 1 window doesn't work... any help is appreciated,.
sw2cam Feb 21, 2011 08:23 PM
Warranty?
ballin00gtp Feb 22, 2011 07:32 AM
no it's outside of the 3 -36k. i'm not sure what it could be.. from what the information that i gathered is the heated seats and sunroof are on one fuse, the mirror is powered from the sunroof. but the drivers side window doesn't make sense... any ideas?
OceanArcher Feb 22, 2011 09:54 AM
Well, I agree that its unusual for two different fuses to fail at the same time, but you need to check all the fuse blocks and replace any blown fuses. Then let us know what still doesn't work (if anything) and we'll go from there
ballin00gtp Feb 23, 2011 08:25 AM
alright so i replaced the one fuse that was labeled heated/sunroof and all things are working again except the auto up/down feature on the drivers side window.. What could cause the 10 amp fuse to just blow?
OceanArcher Feb 23, 2011 08:35 AM
OK - so as I read your comment, your problem with the driver's side window is that it will not auto up/down. I'm assuming here that the window will operate with the switch held manually, just like the other windows -- am I correct ??
ballin00gtp Feb 23, 2011 08:39 PM
yes it will work by holding it.. so im not really sure... im kind of surprised that there were that many things hooked to 1 10amp fuse...
sw2cam Feb 23, 2011 08:51 PM
Auto up and down is controlled by the switch, so it's dirty or worn out.
OceanArcher Feb 23, 2011 10:01 PM
They don't expect all them things to be on at the same time. As far as the autoup/autodown, theres an "express module" EM that has probably gone sour. Don't remember if its mounted in/on/near the window switch or the window motor, so you'll have to check with someone else on that .....
ballin00gtp Feb 24, 2011 07:51 AM
yeah i can understand that, but i have a single heated seat and sunroof on my grand prix gtp.. and it's on a 15 amp.. just kind of shocked me.. would i cause any damage if i upped the amps to a 15 in the saturn?
