Cracked 2.2 Exhaust Manifold
I agree the Dorman manifold I purchased is probably not up to GM quality but the immediate concern is to remove the broken stud from the head. Derf is right the best and only real way to deal with the stud issue is to remove the head then take it to a machine shop. This will be a lot of work and replacement parts...hope my boy appreciates it!. I'll report back when done. Thanks
I have replaced several broken studs on several L61 engines. Most have still been on the car. They are usually not very tight in the head. If you can drill down into the stud an easy out pulls them right out.
Rubehyseed; I gave that some thought. I know a great welder who does excellent welds and fast but not cheap!. If I still had the old GM manifold I would give it a try but don't really want to mess with this Chinese manifold.. I go to the junk yards at times.....for therapy....an will keep an eye out for a GM manifold. If I can get it for 25 dollars or so I'll buy it as a back up! BTW you have an interesting posting name. Thanks .
I'm going to try and drill out the stud which would be the easiest solution then put on the Chinese manifold I already purchased....thanks Mr. Dead for your manifold offer. I noticed the Aura has a bit of a different manifold design and might be harder to locate in the salvage yards anyway. I'll post how this turns out. Thanks my friends.
And double d sounds cooler than mr. Dead. Who doesn't like doubleDs 🤣
