A/C condensation
I have a problem locating the condensation tube for the A/C. The passenger side rear floor board gets soaked. I've noticed very little condensation dropping to the ground after using a/c. Worse during conditions of high humidity. Any help would be greatly appreciated. I have an '08 Saturn Aura with 3.5L
Uh huh ..... and by any chance, does your Aura have a sun roof??
(Post 21742)
You'll have to do a bit of disassembly work under the center of the dash. Behind the covers you should find the drain hose which is supposed to go to the outside of the car. Either the hose is plugged (forcing condensate to overflow the catch pan), or the hose itself has become disconnected from the catch pan assembly
(Post 21754)
