Aura brake problem
Bought a 2008 Arua XE brakes work normally when purchased. Was told it needed rear brakes the parts came with the car.
Noticed one of the rear calipers was cracked so decided to replace everything. All new calipers, rotors and brakes all around. Bleed the brake system multiple times as would be done with other cars. When car is off brake pedal is good Once you turn the car on brakes drop to floor no pressure Do Saturns have any special bleeding procedure for the ABS ? |
I would assume all 2008 GM cars have special abs brake bleeding protocols. Since no one hear has an Aura please look at Chevy Malibu forums for the information you need.
Thanks Andy |
| All times are GMT -5. The time now is 03:50 AM. |
