Aura brake problem
Old May 15, 2023 | 09:55 AM
kdrifter440's Avatar
Default Aura brake problem
Bought a 2008 Arua XE brakes work normally when purchased. Was told it needed rear brakes the parts came with the car.
Noticed one of the rear calipers was cracked so decided to replace everything. All new calipers, rotors and brakes all around.
Bleed the brake system multiple times as would be done with other cars.
When car is off brake pedal is good
Once you turn the car on brakes drop to floor no pressure
Do Saturns have any special bleeding procedure for the ABS ?
Old May 15, 2023 | 08:13 PM
I would assume all 2008 GM cars have special abs brake bleeding protocols. Since no one hear has an Aura please look at Chevy Malibu forums for the information you need.
Thanks
Andy
2008vueXE
Jul 1, 2024 06:34 PM
buftfan
13
Apr 6, 2020 07:36 AM
ngrome
Mar 16, 2011 04:16 AM
mjmeredith
Sep 21, 2008 07:04 PM
toby
May 13, 2005 06:51 PM
